Stator Cover Replacement
Old Jan 27, 2007 | 04:14 PM
VP's Avatar
VP
Default Stator Cover Replacement
I just bought a stator cover off ebay for the left side... and I want to know how the hell to replace it. I thought it would be a simple remove-replace. But it appears not...apparently the alternator is fused to it with loctite... I don't want to replace the whole damn thing
Old Jan 27, 2007 | 11:07 PM
arkas's Avatar
Default RE: Stator Cover Replacement
Hope this helps
http://photos1.blogger.com/x/blogger...92/Stator1.jpg
http://photos1.blogger.com/x/blogger...77/stator2.jpg
Old Jan 28, 2007 | 11:17 AM
VP's Avatar
VP
yeah I've got the manual, I'm wondering if the guy who told me it was secured with loctite just didn't know wtf he was talking about... preciate it though
Old Feb 7, 2007 | 11:58 PM
demonchild's Avatar
loctite is made so bolts dont back out due to vibrations and the like. the seal can still be easily broken with force.
Old Feb 8, 2007 | 12:09 AM
bobjoezx's Avatar
locktite is just for bolts.. and is put on right before you insert the bolt. .takes a little extra force to break bolt loose so use the right size socket but can easily be removed
Old Feb 12, 2007 | 09:38 PM
crazy900rr's Avatar
ORIGINAL: vpsophmore
as opposed to the stator cover for the right side? it is a simple remove/replace put it back together just like you took it apart. If there was locktight on the bolts when you took them off, put some on before you install them.
Old Feb 12, 2007 | 11:55 PM
sixs929's Avatar
Swapping the stator from the old cover to the new one is easy, too - but take a good look at it while you've got it out, checking for signs of overheating , etc.
The thing that surprised me when I did mine was the force needed to pull the stator and cover away from the magnetized rotor that stays with the engine - and that same magnetism just about yanks it out of your hand when you're re-installing the new cover and stator on the engine. Otherwise an easy job.
Old Mar 25, 2007 | 01:15 AM
electronspeeder's Avatar
Well, I just did it this afternoon. It definitely wasnt as easy as I expected... not just a "pull cover off, put on new cover." I guess I was a bit surprised that you need to transfer all that electrical coil/rotor stuff from the old cover to the new cover, which was bolted on *really* tight. And the old gasket basically disintegrated so I had to scrape it off of the bike and clean it off before I used a new gasket and sealant. But all in all, I think I have it back together properly. The bike still runs normal... for now.
HonDashi
Nov 1, 2011 02:25 AM
yog182
May 7, 2009 12:57 PM
Tn929rr
Aug 17, 2007 05:07 PM
