Stator Cover Replacement
I just bought a stator cover off ebay for the left side... and I want to know how the hell to replace it. I thought it would be a simple remove-replace. But it appears not...apparently the alternator is fused to it with loctite... I don't want to replace the whole damn thing
Hope this helps
http://photos1.blogger.com/x/blogger...92/Stator1.jpg
http://photos1.blogger.com/x/blogger...77/stator2.jpg
yeah I've got the manual, I'm wondering if the guy who told me it was secured with loctite just didn't know wtf he was talking about... preciate it though
ORIGINAL: vpsophmore
Swapping the stator from the old cover to the new one is easy, too - but take a good look at it while you've got it out, checking for signs of overheating , etc.
The thing that surprised me when I did mine was the force needed to pull the stator and cover away from the magnetized rotor that stays with the engine - and that same magnetism just about yanks it out of your hand when you're re-installing the new cover and stator on the engine. Otherwise an easy job.
Well, I just did it this afternoon. It definitely wasnt as easy as I expected... not just a "pull cover off, put on new cover." I guess I was a bit surprised that you need to transfer all that electrical coil/rotor stuff from the old cover to the new cover, which was bolted on *really* tight. And the old gasket basically disintegrated so I had to scrape it off of the bike and clean it off before I used a new gasket and sealant. But all in all, I think I have it back together properly. The bike still runs normal... for now.
Tn929rr
Aug 17, 2007 05:07 PM
600, 929, 954, cbr, compound, cover, f3, gasket, honda, install, installation, installing, instructions, removal, replacement, seal, stator
