Starting problems...
Old May 25, 2011 | 08:00 PM
txsmainevent's Avatar
Originally Posted by ajzcamaro
I wasn't sure what the manual said bc I don't have one. I know higher octane decreases hp and can cause detonation issues unless the vehicle has an upgraded ignition. He was talking about running some sort of treatment bs has in shop that supposedly fixes the ethanol problems, which I bc the ethanol is still on the gas. Of course I don't know if this is the problem but we will see.
https://cbrforum.com/forum/cbr-954rr...-manual-23443/
There you go bro, download the electronic technical manual..... They have troubleshooting procedures to diagnose the R/R
Old May 26, 2011 | 05:19 AM
ajzcamaro's Avatar
Got that one downloaded and printed. I thought you were talking about the owners manual. To be honest I didn't even think to look for it until he mentioned it lol. That's what I get for assuming I guess!
Old May 26, 2011 | 09:02 AM
moosestang's Avatar
Higher octane does not cause detonation, fuel with to low of an octane rating will.
I would also agree with vapor lock. My buell cycles the fuel pump when it's hot to prevent vapor lock. Try flipping the run switch a few times, next time.
Old May 29, 2011 | 02:10 AM
ajzcamaro's Avatar
Default Update
Ran the bike until it was 216 degrees and cut it off. Tried to restart but it wouldn't. I used my spare key to pop open the gas cap incase it was vapor locked but she still would not start until cooled off. There goes my vapor lock theory...
Old May 29, 2011 | 10:32 AM
moosestang's Avatar
The vapor lock is happening in the fuel lines. Opening the gas cap isn't going to do anything. Try wrapping the fuel lines in heavy duty tin foil and see if it does it again.
Did you try cycling the run switch a few times so the pump will pressurize the lines?
Old May 29, 2011 | 02:05 PM
letsride's Avatar
I have checked the R&R and it is within proper specs.
Old Jun 17, 2011 | 10:56 PM
ajzcamaro's Avatar
I ran a tank of 93 octane non-ethanol gas and still had the same problem. I will try the 87 octane next bc they don't have a midgrade at that gas station. I even tried cycling the run switch but that didn't help.
Old Jun 18, 2011 | 01:00 AM
letsride's Avatar
been there done that and still have the same problem.Hard to see what can be the problem.
Old Jun 18, 2011 | 04:56 PM
Conrice's Avatar
throwing this out there, but it could be worth a check: crank sensor? that causes problems with heat... i had a gs500 that did exactly what you're talking about and it ended up being the crank sensor
either way, its electrical since it's an issue with heat
Old Jun 18, 2011 | 06:09 PM
ajzcamaro's Avatar
Yeah I think it's definitely an electrical issue. Did you try bypassing that sensor you were talking about, letsride?
