Revving under no load
Old Nov 25, 2012 | 02:59 PM
Dazed's Avatar
Default Revving under no load
A no load rev is when the bike is stopped and in neutral, But when riding would it be considered a loaded rev if you pull in the clutch while moving and rev it? People say no load revs damage valves etc.
Old Nov 25, 2012 | 05:21 PM
MadHattr059's Avatar
The danger from no-load is ...it's easy to blow-past the redline.
You can cause damage, by exceed rpm limits by too much and/or too long.
It can lead to oil starvation of the mains and the valve train.
Valves can actually 'float' (the inertia exceeds the springs ability to
follow the cam on the down-side) leading to timing errors.
On older pre-electronic ignitions, the spark can lose it's ability to keep up.
This is generally an issue with earlier engines. Modern engines have rev-limiters
and electronic safe-guards. So, except for the really stupid, it's not really an issue.
Ern
Old Nov 26, 2012 | 06:44 AM
Dazed's Avatar
Thank you.
Dazed
Nov 23, 2011 09:07 AM
Bugkiller
Apr 12, 2011 03:00 AM
P_Glasovatz
Sep 30, 2009 01:28 PM
nlau
Jul 29, 2009 06:31 PM
AlexF4i
Oct 3, 2008 05:45 PM
