Replacing front brakes
its simple, takes bout 30 minutes top! here is the weblink from the how to topic about replacing brake pads. i would explain but this is real detailed and its a great thread.
https://cbrforum.com/m_30265/tm.htm
very easy for anyone with half a brain about mechanics.. remove calipers, remove pads, push back piston, put new pad in, reinstall caliper, bleed a few times after and top off fluid if need be, great time to replace to steal lines also
