Removing Headlight...
Old Apr 19, 2009 | 02:12 PM
Everlst's Avatar
Default Removing Headlight...
I am having an issue removing the headlight from my upper cowling, the 2 screws at the left and right bottom are just spinning and not coming out, has anyone else seen this issue? The one at the top of the headlight came out fine, this is the first time I've tried to take it off and it looks simple but cant figure out, any advice would be great!
Old Apr 21, 2009 | 09:37 PM
RPM_RIPPA's Avatar
Well first, don't get pissed. Second, u can get it out and its not gonna take a lot. Basically pull it out, there is a piece that the screw tightens into (and it has loosened itself from the plastic around it) and the screw must be in too tight. Therefore the screw just spins the piece its screwed into and it all spins. Once you take out all the other screws, then just gently yank those two out. I glued mine back in when I had it happen, but haven't tried to take it off since so I can't say how long it'll last.
jharbinson
Apr 17, 2009 12:20 PM
drewbagel423
May 24, 2008 09:22 PM
ssjnimma
May 6, 2008 03:42 PM
cyber00677
Aug 3, 2007 03:57 PM
some guy #2
Jun 5, 2007 12:00 PM
