Rear brake sticking, help
Old Dec 20, 2006 | 06:48 PM
doogstar's Avatar
Default Rear brake sticking, help
I was inspecting my bike today and noticed that my brake light stayed on when i pushed the rear brake. Sucks. When i manually pulled it up, it went off. Is there something I can do before I am forced to take it in to a shop to be looked at?
Old Dec 20, 2006 | 08:39 PM
VP's Avatar
VP
Default RE: Rear brake sticking, help
mine does the same thing man you just gotta pull up on it with your foot after you use it
Old Dec 20, 2006 | 08:55 PM
outsider8's Avatar
ORIGINAL: doogstar
try checking and/adjusting the switch first-also check the return spring
o8
Old Dec 20, 2006 | 09:00 PM
bobjoezx's Avatar
adjust the spring.. and switch... under the level there it turns left and right
Old Dec 20, 2006 | 10:00 PM
doogstar's Avatar
Thanks fellas
Old Dec 20, 2006 | 10:07 PM
doogstar's Avatar
Bobjoe, I did what you said, and it worked, thanks alot bro.
Old Dec 22, 2006 | 01:46 PM
VP's Avatar
VP
ehh? what's this I'm hearing? where is it at?
Old Dec 22, 2006 | 02:34 PM
outsider8's Avatar
lower inside of right side rear set-you will see the switch and return spring
the switch is threaded,just rotate disc/nut tillthe switch isproperly adjusted to
the brake lever
o8
Old Dec 23, 2006 | 03:45 AM
bobjoezx's Avatar
yep exactly, glad could help
Old Jan 1, 2007 | 12:10 PM
doogstar's Avatar
Just wanted to be the first to post in 07. Happy New Year!!
wetawded87
Mar 1, 2013 11:28 PM
Hayden06F4i
Jun 17, 2008 09:50 AM
BigMike0147
Feb 21, 2008 01:16 PM
jmc
Jun 30, 2007 06:04 PM
BoRkA
Feb 2, 2007 01:06 PM
