Power Commander Install
Old May 15, 2009 | 12:16 PM
King Klong's Avatar
Default Power Commander Install
Hey everyone. Just a quick question on how to install a Power Commander. I found a 3r version on ebay, and got it for 100 bucks shipped. Only thing is it doesn't come with instructions. I saw on the Dynojet website that it should be very easy, and not take a lot of time. A friend with the same bike put one on his though, and said it was not as simple as it is made out to be.
From what I hear I should be able to remove the front seat, lift the tank and connect it. My buddy recalls having to remove one side fairing though. Is it as simple as the site makes it out to be, or as difficult as what my friend says?
Also, I searched the threads before posting, and didn't find anything other than people looking for maps and comparing horsepower. One person said that the PC3r made their bike run terrible. Anyone else experienced this?
Thanks in advance.
Old May 15, 2009 | 03:44 PM
RumbleFish's Avatar
It is pretty simple. You be able to get install instructions from the Dyno Jet site.
There's even an 800 number you can call and they'll help you w/ the install & mapping.
Yes, you will need to remove seat, and lift tank up (empty tank is easiest)
Mapping is super easy on any PC, maps available all over the web.
If properly installed & mapped, your bike will run much better.
good luck!
Old May 19, 2009 | 11:23 AM
King Klong's Avatar
got this done last night. i took my time with it so the 5-15 minute range was exceeded. That main plug is a pain to disconnect, but I made it happen with a pair of large pliers and a long, thin flathead screwdriver. I also took a minute to cut some notches in my battery tray for the wire to pass through which allows it to hug the subframe instead of running over or around the battery.
Old May 19, 2009 | 11:32 AM
RumbleFish's Avatar
so, how's it runnin'? I had a blk/red '02 954...one of the best I ever owned. The 954 is an excellent bike. Yes, the front end can be a bit 'twitchy' but a damper solves that straight away.
Old May 20, 2009 | 07:44 AM
King Klong's Avatar
it runs nice. a smoother response, and maybe just a little quicker overall. i still don't know what map is in the pc though. the seller didn't provide the serial cable it uses so I have to go find one(hopefully tonight after work).
the only time i've felt the twitch you talk about is if i'm leaving a line hard, and hit 2nd really good. i like doing this though cuz i can get a slight wheel spin hitting second.
Old May 20, 2009 | 11:52 AM
RumbleFish's Avatar
the 954 was known for being a bit twitchy coming out of corners when hard on the gas.
As for the cable, check the one that comes w/ your cell phone. The USB cable that comes w/ many phones is the same as the one that comes with the PC3.
Old May 20, 2009 | 09:03 PM
King Klong's Avatar
the connection on PC3r isn't like the others. It's called a DC9 Serial connector. I just payed $45 for a cable with a circuit board in it that goes from that to USB. Cost of my PC3r is now at $145. Not to bad I don't think.
So with the cable I finally got an accurate map loaded. Can't wait to head to work tomorrow, and ride a little after.
CBRfenatic93
Jun 15, 2012 01:37 PM
oodayvidoo
Nov 21, 2007 11:08 PM
Glocker23
Feb 21, 2007 02:17 PM
red87tll
Aug 8, 2006 10:03 PM
lang1864
Apr 27, 2006 12:38 AM
