pc ya or nay ?
Old May 20, 2011 | 01:00 AM
moses25's Avatar
Default pc ya or nay ?
considering getting a power commander but just want feed back if its worth it or not and i also was wondering if anyone removes the flap assy in the exhaust i did it on my gsxr kida a pain in the *** not so much worth the hassle but could work out better on my 954 anyone know of a good write up on that ?
Old May 20, 2011 | 05:19 AM
txsmainevent's Avatar
A pc is def worth it if you have a full system and are getting a custom tune.
As far as the flapper, just remove the cables and lace it open like mine is. Also remove the airbox flapper if you haven't already. Last but not least order a servo eliminator module for 30 bucks....
Old May 20, 2011 | 10:49 AM
t4rusaf's Avatar
Sept. 2011 Ride of the Month
You'll only really see the power/difference with a custom tune. Lots of people are happy with borrowed PC maps for similar setups but a custom tune for your bike would be best. Every bike is different even if the same exhaust/mods are done.
Old May 20, 2011 | 10:59 AM
Ironhead's Avatar
PC and custom map will go hand in hand. I ran the PC3Usb with the supplied map from Dyno jet for about a week. Once I handed her off to my Tuner. He fixed it right! Night and Day difference! The Dyno jet map for my system was a mess. Fuel curve looked like watching deadliest catch with a storm coming in....Even if you have not upgraded your exhaust. I say its worth it...IF!!! you are going to get a custom tune. Mind you. If you do any upgrades after the tune. You will need to do it again. If you are just looking to "wake" the bike up. Try -1/+1 or -1/+2! The gear swap should keep you grinning for awhile.
Old May 20, 2011 | 12:33 PM
Conrice's Avatar
ya its def worth it. but like everyone has said so far, the only way to get the most out of it is a custom tune. so i'd figure out all your motor mods first then do it. you can get it now and run a dynojet supplied map - it'll feel better than stock, but you won't be getting the goods out of the PC until you custom tune.
Old May 20, 2011 | 11:39 PM
moses25's Avatar
is the servo eliminator modual basically too trick the ecu into not throwing a check engine light ? and were can i buy one of these bad boys ? on my gsxr i removed everything and snipped a wire too the ecu so a check engine didnt pop up obviously my 954 is not that way lol must say tho this bike is an absolute joy all around and ive rode em all and everone has been really great and helpful on this forum so thanks for that to all
Old May 21, 2011 | 08:58 AM
Conrice's Avatar
PM'ing you now
