Opinions needed
Old Jan 10, 2009 | 08:55 AM
wv99xj's Avatar
Default Opinions needed
Im looking at an 02 954 with 27k miles and a problem with 4th gear. It looks like the chain broke and cracked the case also. Overall the bike is clean with new tires and shifts good to the other gears. Whats it worth?
Old Jan 11, 2009 | 12:25 AM
TK954RR's Avatar
Jan 2009 ROTM
Default RE: Opinions needed
Well when you say case it makes me assume the block, if thats correct then not much. I would also say it depends onyour mechanical ability, cause it sounds like you may be putting a new motor and trans in it.
Old Jan 11, 2009 | 01:50 AM
albigman's Avatar
Funny subject because i had the same about a month ago. I was also looking at a 27k mile 954 and ended up getting it for 4500. It was a single owner vehicle and clean with good maintenance records just to put it into perspective.
Old Jan 11, 2009 | 08:17 PM
Hcstreetriding's Avatar
ORIGINAL: TK954RR
+1, you will have at least a grand wrapped up in a used motor if you can do all the work yourself, if not then even more. If your able and willing to do the work i would say it would be worth 2500, give or take.
Old Jan 13, 2009 | 10:17 AM
wv99xj's Avatar
The part that is broken is the case of the tranny where the sprocket is. Nothing that is keeping the bike from running or making it leak oil. Im not sure what the 4th gear problem is though. It will go in sometimes but sometimes it wont. Bent fork? Bent shaft? I dont know much about this bike so Im not sure what to expect.
Old Jan 14, 2009 | 11:45 PM
CBRinPDX's Avatar
I'd avoid that bike and keep looking.
Old Jan 15, 2009 | 09:28 AM
wv99xj's Avatar
OK, thanks.
optytrex
Nov 21, 2012 11:41 AM
CBRmonst3r
Sep 29, 2012 07:26 AM
itsme71190
Apr 28, 2011 03:07 PM
Ludefreak
May 15, 2007 08:34 PM
silvr002001
Dec 19, 2006 10:23 PM
