oil overfill
Old Apr 29, 2011 | 11:27 PM
moses25's Avatar
Default oil overfill
i over filled my oil a little bit just passed the max line is this a hudge deal ? ive road 50 miles scince no problems
Old Apr 30, 2011 | 07:40 AM
MadHattr059's Avatar
A little PROBABLY won't hurt.
That said, if it is a little too much, it can blow your head gaskets (don't ask why I know this).
Oil is relatively cheap. Why settle for less than perfect for your baby?
I would loosen the drain plug, bleed a little out and then, carefully, top it back off to the mark.
Ern
Old Apr 30, 2011 | 03:44 PM
moosestang's Avatar
If you have some fish tank air tubing, you can siphon some out of the fill hole.
Wouldn't the oil blow out of the crankcase breather and into the air box way before the head gasket lets go? Head gaskets are pretty heavy duty.
Michaud85
May 12, 2010 01:59 AM
