off timing?
Well i was changing my sprocket last night and when changing the front one i have noticed that i had moved my crankshaft a little.I took my bike to work today and it feels weak as hell. Does anyone know what i have to do to put it back the way it should?
Dont matter, that would have 0 effect on anything. You turning the front sprocket, turns the whole engine, no effect. Now if your timing chain was off at the time for example, then you would have issues.
ORIGINAL: 954RR RH
a larger front sprocket or a smaller rear sprocket can cause the gear ratio to be higher.A taller ratio would equate to less bottom end power. What did you put on it?
