off timing?
Old Jun 9, 2008 | 11:37 AM
954RR RH's Avatar
Default off timing?
Well i was changing my sprocket last night and when changing the front one i have noticed that i had moved my crankshaft a little.I took my bike to work today and it feels weak as hell. Does anyone know what i have to do to put it back the way it should?
Old Jun 9, 2008 | 07:18 PM
TK954RR's Avatar
Jan 2009 ROTM
Default RE: off timing?
Dont matter, that would have 0 effect on anything. You turning the front sprocket, turns the whole engine, no effect. Now if your timing chain was off at the time for example, then you would have issues.
Old Jun 9, 2008 | 08:11 PM
TENNBANSHEE's Avatar
ORIGINAL: 954RR RH
a larger front sprocket or a smaller rear sprocket can cause the gear ratio to be higher.A taller ratio would equate to less bottom end power. What did you put on it?
Old Jun 11, 2008 | 11:23 AM
954RR RH's Avatar
I drop one from the front.
Old Jun 11, 2008 | 03:19 PM
if you dropped 1 tooth on the front and the bike feels weaker, you have other issues not related to the final drive.
StrongPerf
Jan 2, 2010 04:37 PM
weekendrider
Feb 3, 2008 03:58 AM
allenpa5
Aug 16, 2007 02:59 AM
BiziB
Nov 4, 2006 11:54 PM
one2gofast
Jul 19, 2006 02:46 AM
