new grips wont fit
Old Mar 12, 2011 | 05:40 PM
haaris954's Avatar
Default new grips wont fit
Hey guys got some new grips for my bike but the bar ends won't go in as much as they used to. Has this ever happened to anyone? The left one really looks off. I can't tighten the bar ends anymore they just keep going round n round...any ideas?
Old Mar 12, 2011 | 06:49 PM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
I'll be taking mine off next week for some upgrades but I haven't had them off yet. However, here's a question: Are both bar ends the same length? Just wondering if the threads on one side are longer than the other and maybe you have the two reversed.
Also, are the new grips the same length as the old ones?
Old Mar 12, 2011 | 07:42 PM
moosestang's Avatar
Your throttle grip looks like it needs to be pushed on more. Are you sure you installed the bar end correctly? Most of them lock in place before you tighten them, so you may need to loosen it then spin it around until it drops in place.
Old Mar 13, 2011 | 10:01 AM
Conrice's Avatar
right on.... you need to turn the bar end 180 degrees and it will fit into place so that you can go further with the bar end bolt (pull it off and look at it, you'll see what i mean)
Old Mar 13, 2011 | 06:07 PM
letsride's Avatar
I had a set of grips like those,I believe they are a bit shorter than the oem ones.
Old Mar 14, 2011 | 04:15 PM
haaris954's Avatar
yeah the new grips are a little smaller...but right now it is off a lot more than it should be...i'll try switching and some of the other things you guys suggested! Thanks.
Old Mar 15, 2011 | 11:32 PM
theskater101388's Avatar
yea the throttle grip needs to go in further. try shootin some compressed air in the end of the grip in between it and the throttle tube. works wonders for putting grips on.
C Jacob W
Jul 29, 2013 11:03 AM
tagger609
Jun 27, 2008 02:09 PM
jc8115
Apr 17, 2008 11:17 AM
mishab
Sep 7, 2007 01:00 AM
seldon929rr
Jun 10, 2006 06:58 PM
