need info help please =]
Old Mar 3, 2011 | 11:28 PM
davpan12's Avatar
Default need info help please =]
I bought my cbr like 2 weeks ago and i just got the plates. But when i went to my bike i forgot that i dont have the stock tail lights i have a interngrated turn signal into the brake light so i dont know how i can mount my license plate there =[
Old Mar 4, 2011 | 08:05 AM
txsmainevent's Avatar
Many ways, take a pic of the back side and post it. Ill be able to help you. There are tons of ways to mount it....Pics would help
Old Mar 4, 2011 | 08:21 AM
Joe 96 CBR F3's Avatar
I have seen many different ways, but as pimpncbr said pics are a must, they will help a bunch to see what ways will work for your set up.
Old Mar 4, 2011 | 08:33 AM
davpan12's Avatar
Default heres a pic from my phone
my phone sucks! ugh. um with this pic ill try to explain it as best as i could. I am looking at the back of my bike and i see 3 holes. Is there something i can buy that connects to the 3 holes that can connect to a license plate? Chicago cops are strick and i dont want to give them a reason to stop meh!
<a href="http://s57.photobucket.com/albums/g232/ilovecraig69/?action=view&amp;current=2011-03-03224222.jpg" target="_blank"><img src="http://i57.photobucket.com/albums/g232/ilovecraig69/2011-03-03224222.jpg" border="0" alt="Photobucket"></a>
if you cant see the img above then go to http://i57.photobucket.com/albums/g2...3-03224222.jpg
Old Mar 4, 2011 | 10:04 AM
regener8ed's Avatar
photo is too dark to see. where did the PO have the plate?
Old Mar 4, 2011 | 10:10 AM
And as I am at work any public sharing website such as photobucket is blocked. I'll check back later to see any pictures, unless you attach them to your post.
Old Mar 4, 2011 | 10:16 AM
You can buy one of the inspection plate holders (usually around 5-10 bucks at any motorcycle shop) and mount it that away. Underneath the brake light bolted to the undertail and under the seats. Simple quick and very visible.
You could also purchase some L shaped brackets from home depot or lowes and mount it the exact same way.
You could use the bolt holding the chain gaurd on the swingarm and bolt it there with one bolt.
Ive bought a hose clamp big enough to mount it to the exhaust.
There are many possiblities, and simple ones too.... just get creative.
Old Mar 4, 2011 | 11:22 AM
davpan12's Avatar
The previous owner just had some rope and tied it to underneath the storage compartment. Is there a place online i can purchase the thing you where talking about pimp? I don't have many motorcycle shops by me
Old Mar 4, 2011 | 11:47 AM
Conrice's Avatar
hey, i couldn't exactly tell by your picture, but im pretty sure that you have the same situation as me. all you need to do is go to home depot, and get a 7in. piece of aluminum stock. you can connect that to the tail section where your turn signals used to go, and then drill two holes on the end to connect the plate. i've attached a pic to show you what i mean. if you look closely, you can see the aluminum stock right behind the plate.
Old Mar 4, 2011 | 12:01 PM
davpan12's Avatar
Nice bike Conrice =]. So you got this 7in piece of aluminium stock drilled it into those 3 holes behind that that normally the stock turn signal plastic holders would connect to then you drilled holes to mount the plate is that what your saying?
