map sensor check engine light.
Old Jun 21, 2010 | 11:04 PM
svt954's Avatar
Default map sensor check engine light.
My 2002 954 check engine light is on. I checked the code and cross referenced the service manual. The code is for the map sensor. Will replacing the map sensor w/ a brand new one fix the problem? Has anyone ever had similar problems?
Old Jun 22, 2010 | 05:10 PM
letsride's Avatar
Should fix it but I would also check for any loose wires that may have caused the light to come on.Never has happened to me though.
Old Jun 22, 2010 | 05:55 PM
Chamoru671's Avatar
My check engine light when on for the map sensor, found out it was only loose wires.
Old Aug 6, 2011 | 11:23 PM
Omaha rider's Avatar
How can you tell the code if the light is on solid?
rpetro24
Apr 5, 2021 12:54 PM
silverstonef4i
Mar 16, 2010 05:54 PM
edimean22
Feb 21, 2010 10:55 PM
xjoex
Jun 17, 2009 06:26 PM
CBR BoyRacer
Aug 17, 2007 10:43 PM
