lucas oil in a 954rr
Old Sep 19, 2008 | 08:52 PM
paseo12's Avatar
Default lucas oil in a 954rr
Hey just wondering if anyone has ran lucas oilin their bike?... I love the performance in the car but not sure how it would be for the bike... Let me know if anyone has used and the results they got...
Thanks Scott
Old Oct 9, 2008 | 07:59 AM
schwinn's Avatar
Default RE: lucas oil in a 954rr
Personally, I will never use Lucas Oil Stabilizer in ANY vehicle after seeing this: http://www.bobistheoilguy.com/images/lucas/lucas.htm
I can't imagine how much worse it would be in a high-revving motor like a motorcycle.
Fact is, quality oil has all the right stuff in it already... no need to add more junk to it.
Old Oct 9, 2008 | 08:26 AM
TK954RR's Avatar
Jan 2009 ROTM
I have used Lucas in my race cars for over 15 years, and will continue to do so. I trust my long term results over Bob and his machine.
That said, i would not use it in my bike, main reason is the clutch, it does not like additives.
Old Oct 9, 2008 | 07:22 PM
paseo12's Avatar
Thanks guys, I found some lucas oil for motorcycles... I think I will give it a try next spring... I love it in my cars, but like you said TK954RR about the clutch I dont want to mess that up... If anyone has tried this oil please let us know if there was any difference... Thanks again guys...
Scott
Old Oct 10, 2008 | 02:39 PM
schwinn's Avatar
Just to be clear, I was speaking about Lucas Oil Stabilizer, not their oil itself.
TK954RR - I respect your opinion, but I wanted to know - do you have any data (UOAs, for example) to show that it's better to use Lucas instead of nothing? I mean, it's very possible that the engine simply "can take it"... but that doesn't mean it's good/better for it. I figure a UOA may show something concrete... and being a racer, maybe you do UOAs anyway?
Old Oct 10, 2008 | 07:58 PM
TK954RR's Avatar
Jan 2009 ROTM
I dont. This a drag car, it gets torn down 3-4 times a year. I cannot say it wouldnt be fine without it, or its better with it. All i can say is i use it all the time, and when i tear down the block it always spotless. I have no proof of any kind, it one of those deals, if it aint broke dont fix it. That is why i say i trust my results, i use it, i have had no problems using it, and i prefer those results over a test that was shown. No more, no less.
Old Oct 13, 2008 | 10:21 AM
ModMotoMan's Avatar
I wouldn’t use Lucas Oil Stabilizer in a bike but the guy bobs test is shady at best.
What ratio is he using? Or is he using pure Lucas Oil Stabilizer rather then the 20/80 ratio with regular oil or lube?
As for using it in motors you should always test the oil under warm conditions not 60F IMO, this is why we warm our motors before *** whipings right.
I use to play with hot rods too and I was known to use a 20/80 ratio of the lucas Stabilizer to help keep my oil from turning into water. My oil pressure would get real low at idle (10psi) in real hot Florida days with straight oil, When you have a large ci V8 with high compression, larger cam and a nasty idle your oil cooks although your water temp is at normal.
Lucas Oil Stabilizer works well when used for certain things, while using it my oil psi would never get lower then 20psi at idle and as always soon as I bump the throttle she would jump up to 55psi.
hmm
Sep 8, 2011 03:28 PM
dachamp312
Apr 20, 2011 09:24 AM
n_vanexel31
Dec 16, 2007 07:30 AM
PitbullF4i
Jul 14, 2007 11:47 AM
