lowering ft end
lowering the front is easy as hell, first thing tho make sure u get a jack to support the bike when lowering the front end(put it under the headers). all u have to do is loosen the bolts on the upper triple tree, lower triple tree, and clip ons. u only want to loosin them so the forks slide up usin a rubber mallot, there should be a total of 10 bolts i believe (4 for the upper triple tree, 4 for the lower, and 2 for the clip ons). also make sure u measure several times.
Thank you I will take it on soon. we will be drag racing again in 2 weeks and may be now I will be able to keep the Ft. end on the ground a little easyer. My 60 ft times were killing me because all the bike would do is bring the ft wheel up. I think the next thing will be longer swing arm, then a air shifter, turbo or spray. I want to go faster then 10.
