looking for power commander map D&D
Old Oct 13, 2008 | 06:34 PM
slvr05wrx's Avatar
Default looking for power commander map D&D
looking for power commander map for D&D bolt on exhaust for a 2002 954rr
Old Oct 13, 2008 | 07:50 PM
TK954RR's Avatar
Jan 2009 ROTM
Default RE: looking for power commander map D&D
Just download right from dynojets website. Grab the Two Bros slip on with stock or aftermarket air filter. That one is going to be close enough for you. Any downloaded map or even if you got one from someone here is never going to be perfect, all bikes are different. So i would just use that one until you get to a dyno to have your own made. If your not going to dyno, it should still be a better map than stock.
Old Oct 14, 2008 | 09:24 AM
slvr05wrx's Avatar
i was running it on the erion bolt on map, but it was spittin out fuel. i will try the two brothers.
Old Oct 15, 2008 | 06:47 PM
skip954's Avatar
before i had mine dynoed and mapped i was useing the yosh map table 2. but my pipe is a d&d from an r-6 that i cut and welded on.
i took the lap top to the drag strip made a couple passes then changed the map until i was getting my best times. not the best or eisiest but def the cheapest untill i could get the custom tune done........
Old Oct 21, 2008 | 10:45 PM
slvr05wrx's Avatar
anyone have there bike run great after a download, but then run like crap after a few days, and the opposite?
Karmakazi
Sep 29, 2009 09:58 AM
joe-4422
Apr 7, 2009 09:47 AM
five0addict
Sep 21, 2006 06:17 PM
dudek12
Aug 9, 2006 01:13 AM
maxwell139
May 16, 2006 01:30 AM
