k1 forks
RE: k1 forks
Nope, not gonna work........But if thats what your intentions are. Use the R1 forks, because they are already black....w00t!!!!!
Use the top and bottom 929/954 triple clamps. Then use forks, brakes, wheel, rotor and axle off of a R1.
Basically anything with a 50MM fork tube diameter will work, as long as u use the 929/954 triple clamps. Keep in mind that u have to use forks, brakes, wheel, rotor and axle off of whatever the forks come from........But im just showing how it would work....=-)
R1 front end on the F4i........=-)
RE: k1 forks
1000rr will work just fine, a body of mine did that. check it out http://www.bikepics.com/pictures/1451263/
jfunkRR
04-30-2008 09:23 AM
