intergrated tail light
Old 12-27-2006 | 07:29 PM
spidertron's Avatar
Default intergrated tail light
hello i just got a alternatives clear intergrated taillight from ebay. the direction simply said that to connect the yellow wire to the positive wire .. but i do not see any wire for grounding? are the common grounded with a alternative wire somewhere else?
Old 12-28-2006 | 11:12 AM
VP's Avatar
VP
Default RE: intergrated tail light
you have one power wire and one ground wire on the tail section... there aren't running lights for the back...
Old 12-28-2006 | 11:26 PM
spidertron's Avatar
its a intergrated taillight with turn signals
Old 12-29-2006 | 12:25 AM
doncollins's Avatar
Retired Administrator
If I remember correctly... you just need to connect the yellow wires. The turn signals are grounded through the tail light. It's been a while since I installed mine, but that rings a bell for me.
Old 04-18-2009 | 08:48 AM
lkngood's Avatar
I just installed mine - I bought the Intergrated - Sequencial Tail Light.
1) The two Yellow Wires goes to the left and right Positive wire of the turn signal
2) There are 3 wires left (Black, Red, Green)
3) Black wire goes to the ground wire of the stock brake light
4) Red wire goes to the brake wire of the stock brake light
5) Green wire does to the parking light of the stock brake light
6) FYI: You may have to switch the Red and Green wire - either way one is for the parking light and the other is for the brake light.
Pretty simple to install - even with no directions.
ldgriffin
F2 Tech
04-07-2014 10:07 AM
DOOMED
03-07-2008 02:44 PM
Italio13
03-04-2007 11:55 PM
muffinman
06-22-2005 11:52 AM
