Injector issue
Old Feb 20, 2020 | 05:28 AM
Aldarkcloud's Avatar
New Member
Default Injector issue
I got a issue with the 2 outside injectors pumping way too much fuel but the middle injectors seem fine and it will run but idle to about 2500 rpm skips but clears out when you get the rpms up I don’t know what to check or replace I’m kinda new to this type of bike any help will b very much appreciated
Old Feb 20, 2020 | 06:19 AM
74demon's Avatar
How do you know the outside injectors are leaking?
Injectors are basically valves that are open or closed. The amount of time they're open is controlled by the ecu, with the fuel pump providing the pressurized fuel to go through the injector. The best way to see if one is leaking is to pull the fuel rail back from the throttle bodies and pressurize the system to see if there are any drips.
Old Feb 20, 2020 | 07:36 AM
New Member
When I pulled the air box off the num 1 cylinder the valves had a puddle of gas over them n when I pulled the plugs the num 1 n num 4 plug was black and the num 2-3 was fine
Hector Levario
Oct 10, 2018 08:28 PM
JHillCBR
Sep 23, 2012 11:34 PM
MaikuMizu
Sep 9, 2012 04:17 PM
Mondstar77
Dec 21, 2009 05:05 AM
lastchance
May 16, 2009 03:30 AM
