Idle issues
Old May 2, 2012 | 09:11 AM
bikermerc's Avatar
Default Idle issues
My bike roughly and abruptly idles at around 1100-1300 rpms. I checked the exhaust and the the HTEV has been removed...the bike also comes with a PCIII...
I tried adjusting the idle by turning the idle speed screw but it seems there is no change. The weird thing is, sometimes the idling shoots up to 2k rpms, then goes back down...
What's wrong? any solution???
Old May 2, 2012 | 02:06 PM
letsride's Avatar
Your idle is where it should be 1200 +/-100. Now the idle screw might have come loose that is why you can't raise or lower the idle speed.
Old May 2, 2012 | 05:39 PM
CTcbr929's Avatar
July 2012 Ride of the Month
If it shoots up to 2k on a cold start, thats normal.
Our bikes have an 'auto fast idle' similar to cars.
But yea as letsride stated bouncing between 1100-13 is normal idle rpm
Old May 3, 2012 | 05:18 AM
bikermerc's Avatar
It actually shoots up to 2k while i'm riding...when i decelerate to slow down at stops, sometimes the rpms stay at 2k...it's weird...
With regards to the idle screw, where do i check if it's loose?
Old May 20, 2012 | 08:25 PM
bikermerc's Avatar
I'm getting frustrated with my idle problem...I just rode my bike downtown, and the idle often shoots up to 2k rpm and stays there. The temperature is way in the normal temp, so why does it stay there? When i start the bike and allow it to heat up properly, it shoots up to 2k due to the auto fast idle, then when the temps are within range, it goes back down to 1200-1300rpm....
Old May 20, 2012 | 10:43 PM
stealthCBR929's Avatar
Official Glory Detailer
the tps on the side of the throttle bodys could be acting up . you power comander could cause it too do you have a work shop manual ? symptom charts always help . if i were you i would unplug your pc and plug back in the throttle bodies back to stock and see how it runs . power comanders cause drivability problems all the time iv had it happen . also check for vacume leaks too . just take your time you will figure it out bikes are super easey !!! process of elimination ! if you dont have a work shop manual get one asap!
Old May 21, 2012 | 12:04 PM
backdoc's Avatar
PC3's have a throttle position setting that can be calibrated.
http://www.powercommander.com/downlo...User_Guide.pdf
Old May 27, 2012 | 03:40 PM
bikermerc's Avatar
hey everyone...i brought my bike to my mechanic-friend to see what the problem was with the idling. Lo and behold, one of the tiny parts in the throttle assembly was missing, therefore messing up the idling, throttle response and a/f mixture to say the least.
having repaired the problem and cleaning the throttle bodies as well, the bike now idles smoothly, throttle is very crisp and power at the right rpms...plus since my buddy is also a guru at suspension tuning, he made some adjustments to fit my weight and riding style. Now i really enjoy my bike...the difference is like night and day!
Old May 28, 2012 | 11:48 AM
samba2's Avatar
What was that missing part and where it`s located (part number)?
I´m having also a little problem at low rpms.
Night Spirit
Sep 13, 2013 01:22 PM
Tonys02F4i
Mar 16, 2013 06:58 PM
Thanatos
Jul 4, 2010 01:50 AM
mpz
May 11, 2009 10:03 PM
cookiemonster
Oct 28, 2008 12:28 AM
