how to check alternator for charge
Old Aug 10, 2011 | 08:06 PM
graysonwittwer's Avatar
Default how to check alternator for charge
I need to check my alternator to see if it is charging, what is the proper way to do this??
Old Aug 11, 2011 | 09:01 AM
Conrice's Avatar
are you trying to determine if its the stator or the battery?
if so, all you need to do is take the seat off, and with a volt-meter, measure the strength of the battery while the bike is running, and then while it is not running. if its the battery, the voltage will drop down significantly when the bike is not running. if its the stator, the battery will slowly drop voltage while the bike is running.
Old Aug 11, 2011 | 09:49 AM
moosestang's Avatar
Unplug the stator plug while the bike is running, there should be three leads/wires, we'll call them A,B and C. Take a multimeter set to AC and place the meter probes between A-B, B-C and A-C. You should get similar readings from all three legs of the stator. If one is significantly lower, then it's dieing. I'm sure there is info online on how much voltage it should be putting out at what rpms, but for starters I'd test each leg at 3000-5000 rpms and be looking for 45 VAC. You can also test for resistance with the bike off, using ohms on the meter, but we need to know the acceptable range.
Old Aug 11, 2011 | 06:40 PM
MadHattr059's Avatar
Charging System Diagnostics - Rectifier/Regulator Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
https://cbrforum.com/forum/f2-tech-9...-solved-27739/
Check out these two threads. They'll give you a better idea of what to do.
Ern
Old Aug 17, 2011 | 12:00 PM
Thanks for the advice guys!! Turns out my stator is bad. Wonder where I can find a good used one without having to pay $250 for a new one. I think it went bad after a overheated my bike at around 250 degrees after I put a new tranny in and forgot one very important thing... to hook the fan wires back up
Old Aug 17, 2011 | 06:19 PM
HONDA CBR900RR / CBR954RR, 02-03 - Buy the BEST Stator Regulator/Rectifier CDI - ElectroSport
Check these guys out.
Ern
hmm
Aug 28, 2013 07:21 AM
jbalber
Jun 13, 2013 06:01 AM
G_954rr
Dec 17, 2011 10:57 PM
HARDCORP 8654
Jan 8, 2009 05:03 PM
Nevada Fred
Jun 1, 2007 07:42 AM
