Help again!
Old Aug 9, 2011 | 05:04 AM
rudeboy's Avatar
Default Help again!
now my headlights went out no high beams nothing and the bulbs are still good, fuse is still good, theres power to the turn signals, horn, speedo etc just the headlights?! im kinda lost never had this problem before....did anyone have this problem before? if so how did you fix it? thanks again guys i really appreciate it.
Old Aug 9, 2011 | 10:19 AM
Conrice's Avatar
check your connections, all of them.
Old Aug 10, 2011 | 02:12 AM
rudeboy's Avatar
ill double check them everything looked okay all the main connections maybe i overlooked one ill try again thanks.
Old Aug 10, 2011 | 09:28 AM
Conrice's Avatar
i had that happen to me, i couldn't quite figure it out, i just knew the positive on my lo-beam was not making a connection, so i took some speaker wire i had lying around and tied onto the positive post on the headlight and ran it along the harness and tied it to a fuse that ran all the time.... but i'm sure its a loose connection somewhere, you can figure it out
