Headlights dont work?
Old Sep 20, 2014 | 02:42 AM
Ironhead's Avatar
Default Headlights dont work?
Alright 954 ers....Fuse is fine. High beams work. But low beams do not function? Almost 40K on her and this is the 1st issue I have had with her. Any suggestions?
Old Sep 20, 2014 | 06:07 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Burned out bulb?
Old Sep 20, 2014 | 08:52 AM
74demon's Avatar
Like Jeff says, start with the bulb.
Old Sep 20, 2014 | 01:55 PM
Ironhead's Avatar
All 3? All bulbs work on high beam. What are the odds that all of the low beams fried at the same time? Im going to start with the switch and backtrack.
Old Sep 20, 2014 | 02:23 PM
hawkwind's Avatar
Are you positive all three were actually working? You may have been down to the last one, sometimes it's easier to check the simplest things first.
Old Sep 20, 2014 | 02:58 PM
74demon's Avatar
An overcharging charging system can fry all of them at the same time. If they are all blown, def check the voltage.
Does your dash and tail light up?
Old Sep 20, 2014 | 04:18 PM
Conrice's Avatar
All 3?
Your middle is the lo, the outside bulbs are your hi. They're not hi-lo bulbs.
I had the wiring in my lo beam go bad, and I ran speaker wire to the connector from the fuse and it fixed it.
Old Sep 20, 2014 | 04:47 PM
Ironhead's Avatar
Thanks Boys for all the love! Opened up the light switch and I think I found a cure for ebola in there! Cleaned it up. Had a wire decide to let go on the center bulb as well. No body panels pulled in search of relays....Multiple Beers were harmed in this exploratory process. Gods speed my adult beverage friends.
jaCo
Jun 3, 2011 12:12 AM
alysiak00
Sep 25, 2010 02:26 PM
Gotpepsi
May 7, 2010 04:24 PM
Pug
May 28, 2007 03:58 AM
01929RR
Sep 26, 2006 03:16 PM
