H-vix valve and air box flapper
Old Jan 9, 2009 | 11:20 PM
Outlaw 954's Avatar
Default H-vix valve and air box flapper
Has anyone gutted the h-vix valve in the mid pipe and remove the airbox flapper? what where results if you have?
Old Jan 10, 2009 | 08:08 AM
kamikaze2899's Avatar
Default RE: H-vix valve and air box flapper
I ended up with a slight flat spot just off of idle, and the idle got a little rough. I still have to reprogram the power commander to take care of that, which will be a pain, have to go and set up an appt to put it on the dyno. Other than that I haven't noticed any performance gains at all.
Old Jan 13, 2009 | 01:30 AM
CBRinPDX's Avatar
Gut the air box and remove the snorkels, install race air filter and new plugs (if not already) install PCIII, -1 tooth on counter sprocket, DYNO it and leave the HTEV alone.
Old Jan 13, 2009 | 06:33 PM
skip954's Avatar
ORIGINAL: kamikaze2899
same with mine but i did notice a little gain in the mids still have to get to the dyno. i just removed the cables and safty wired the valve at full open see pics
Old Jan 14, 2009 | 12:57 AM
Honda4Ever's Avatar
Yhea I've removed the Flapper asembly, cables, and installed a BMC race filter. I'm still thinking about removing the snorkels though?? I also removed the exhaust valve and replaced it with a Hass type eliminator that I made at work. Still gotta cut the Micron pipe down about 6in. And the PC IIIr should be here tomarrow according to UPS. I'll let you know when I get her fired up. Still searching for a decent map, may go with a tweeked version of the 110-005 map on dynojets web site till spring. Oh yhea forgot about the PAIR block-offs. Did them too.
Old Jan 14, 2009 | 09:24 PM
bubba_finch07's Avatar
what does removing the snorkles help??? (still new to the sport bike thing) i just installed my powercommander III need to update map. and tweek.... about how much does a dyno tune cost est??
Old Jan 15, 2009 | 01:02 AM
Honda4Ever's Avatar
$250 around here. Still waitin on the income tax to get that done.
Old Jan 15, 2009 | 06:39 PM
let us know how the tuning goes with the snorkles, and flapper removed....
Old Feb 8, 2011 | 12:17 PM
backdoc's Avatar
Check out this site directly from Honda. This confirms the reasoning for the flapper and HTEV are environmental for noise reduction.
Honda Worldwide | Noise Reduction
Old Apr 11, 2011 | 12:11 AM
bangin96z24's Avatar
i have the hvix removed, but the flapper is still there and hooked to the cables, and so are the snorkels.. should i remove them?
