Hi, does anyone has a custom map or a map that is for jardine slip on for cbr 954?
Just pick a map from power commander for any slip-on? There is not going to be a big difference in the maps if there is any difference at all from one slip-on to another. I put a PC III on my 954 about a month ago and even with the map for the Two-Bros slip-on I cant tell any change in how the bike runs.
Originally Posted by sirsleepy
I need one also just running the 0 map for now. Jardine cut to 12 inches and K&N
As for the K&N its only useful if you like having an air filter you can remove, clean, re-oil and put back in the bike. It has no performance gain. I have a K&N for my 954 and earlier this month while drag racing I changed between the K&N and stock. My fastest times were running the stock filter.
I took 8 inches off with a chop saw ground all the edges smooth then drilled out the rivets out on the old tip and redrilled and riveted onto the new smooth cut was simple but then mines not carbon fiber though.
