Fork question
Hi everyone, I ride an 04 CB919 and I'm interested in doing a USD fork swap, I was wondering if any of you could give me the diameter of the forks on your 954s where the upper and lower trees clamp on to the tube?
Thanks for the help
BTW, this is deffinately the slickest forum I've run across yet.
Dan
Thanks for the help
Dan
Thanks for the response, I'm assuming the 50mm measurement is on the top clamping surface so I'm also assuming that the lower clamping surface should be 55mm?
Thanks again for the help
Dan
Dan
