fork help
Old Jul 19, 2011 | 10:11 AM
paulooo's Avatar
Default fork help
so i saw the how to section and and the sticky about rebiulding the forks. but if i just want to change the seals and dustcaps what steps can i omit i dont need to change the springs,, my left seal is leaking all over my brake caliper... need help asap..
thanks
paul
Old Jul 19, 2011 | 05:29 PM
MadHattr059's Avatar
Basically, re-building the forks is all about the seals and dust-caps. You only change the springs if you are having a specific issue with them. Tire hop if too stiff, not getting full travel if too light (basically stated, cause suspension theory is a large subject, better dealt with elsewhere).
The bushings generally will be fine, unless you have excessive milage.
And that's about it for basic re-build. One thing I do recommend, double check your
steering-stem bearings. It's not much additional work (if done in tandeem), and is
frequently a similar time/milage issue. Even if they are good, I recommend upgrading to roller-bearings in the stem as a good, bang-for-buck improvement over stock.
Ern
Old Jul 19, 2011 | 08:19 PM
backdoc's Avatar
thanks
paul
You have to follow all of the steps. Even though you are not changing your springs that does not change the procedure you must follow to re-build your forks. I would replace the inner/outer bushings since the forks rarely get taken apart. Also dont fork to buy new crush washers for the bolt in the bottom of the fork.
FlyWheel
Sep 18, 2012 07:49 PM
driyac
Jul 11, 2010 02:40 AM
civicblade
Apr 23, 2009 08:24 AM
WhiteHawk
Mar 17, 2009 10:17 AM
crx2cbr
Jul 6, 2008 01:56 PM
