doh!!!
Old 10-30-2007, 09:11 PM
Default RE: doh!!!
Yeah, and if the dealer can't do it off the number, a lock shop should be able to re-tumbler the lock for MUCH less. It shouldn't take much to take that off yourself. I had ignition problems on my 99 Prelude with an immobilizer and I dealt with a dealer (quoted $1100 in electronics including ECU) and a lock smith who did it for 80 bucks. Just take your time and find the best, most cost effective route.
Old 10-30-2007, 11:14 PM
letsride's Avatar
Default RE: doh!!!
When I had mine done I removed the ignition took it to the locksmith and he read the last three digits and had the keys made in about 10 min.
Old 10-31-2007, 09:06 PM
demonchild's Avatar
Default RE: doh!!!
Where is this number on the ignition? Also how do you remove those one way 8mm allen heads?
Old 10-31-2007, 09:49 PM
letsride's Avatar
Default RE: doh!!!
The numbers are by the pin that locks the handle bars.On those one way allen bolts I would remove the upper tripple clamps put in a vise and chisel them off.Then you can use regular allens to mount it all together.If anybody else has a different wayI would also like to know for the future of corse
