Cooling fan temp setting
Old Apr 9, 2013 | 04:42 PM
shawnee_cbr's Avatar
Out of curiosity, does anyone else have problems restarting their 954 after shutting it down at +215°F? It's kinda embarrassing when it doesn't fire right up trying to leave the gas station
Old Apr 9, 2013 | 05:28 PM
letsride's Avatar
Has happened plenty of times for me.
Old Apr 9, 2013 | 06:21 PM
BadS1's Avatar
My thoughts are Honda designed it this way. The bike has proven to be bulletproof to standard. If you want your bike to have a fan come on at 200.... then basically you'll be riding around with a fan on all the time.
Old Apr 9, 2013 | 07:23 PM
Very valid point BadS1. I'm thinking a standard manual switch install is the way to go for me. Basically, I just want a way to precool my bike so it starts better
Old Apr 10, 2013 | 06:01 AM
letsride's Avatar
954 actually run better at 180* and has more power.The reason our bikes fan starts at 215 is for emission purposes.I have a switch on mine and in the summer,I turn it on around 180 and don't have any problems.And the bike does feel more powerful.
Old Apr 10, 2013 | 08:19 AM
Conrice's Avatar
or if you're in sw fl in august sitting in traffic
- you need a switch to save your thighs from getting cooked.
Old Apr 10, 2013 | 03:00 PM
BadS1's Avatar
Why???
Old Apr 11, 2013 | 04:20 PM
letsride's Avatar
Why???
At 180 your bike makes more power which then are also more pollutants in the air.
Old Apr 12, 2013 | 08:17 AM
Conrice's Avatar
not that i knew that before you posted, but after researching - it seems that higher temps help with fuel combustion with lower amounts of fuel... the sweet zone on all water cooled combustion engines seems to be from 180-195, but most manufacturers run at higher temps (215-230) because it's the best compromise of fuel economy and power
Old Apr 12, 2013 | 12:11 PM
BadS1's Avatar
I can agree and I can disagree. The 954 runs on 80-85 degree day at HWY speeds around 195-200 anyways. 10-15 degrees does not change exhaust emissions very much at all. Heck Buell's run much hotter that with no cooling system other then a oil cooler.
