Clock
this works for me, might work for you: press both buttons together for a few secs and the clock should start flashing, then you can use top button to change the numbers and bottom to switch to minutes or hours or vice versa
once you get the clock flashing, you press one button to change the hour, then the other button to switch over to set the mintues...I'm sorry to say I can't remember which button is which[
Once you get the time set, it should stop flashing after a minute or so.
]Once you get the time set, it should stop flashing after a minute or so.
