BRAKES!!
Old Jun 16, 2008 | 01:31 PM
capinsober's Avatar
Default BRAKES!!
I heard a skiping in my brakes, i took off the right side calipers, found one of the pistons, is not compressing as fast as the others, the brakes still fuunction properly, but i hear the noise, the fluid seames fine, any ideas?
Old Jun 20, 2008 | 02:11 PM
ajohn505's Avatar
Default RE: BRAKES!!
Are you sure you're hearing a skipping? Maybe it's just normal vented rotor noise.
First thing I'd do is give the rotors and calipers a good scrubdown with brake cleaner. If that didn't work I'd flush/fill the brake fluid to make sure it's not just old fluid or air in the lines. If you haven't changed the fluid lately I'd do a flush and fill first.
Lastly, you can rebuild the calipers.
I don't know if the pistons need to really compress at the same speed...
Old Jun 20, 2008 | 03:54 PM
Hcstreetriding's Avatar
the brake disks are free floating rotors, they are made that way to make up for the pistons not compressing at the same speed/rate/time. when one goes in faster than the other it pushes the rotor toward the other brake pad to compensate for the time difference. If you mean what i think you mean thats the explination for that.
As for the skipping i would go with Ajohn and do a good scrubbing with "brake quite" or brake silencer or something along those lines and see if it still makes the noise.
Nytmr
Dec 21, 2013 09:16 PM
CBRInfantry
Feb 7, 2011 09:42 PM
hopz
Jun 4, 2009 01:28 AM
radvoem
Dec 28, 2008 08:38 AM
