brakes
Old 11-01-2007, 12:42 AM
demonchild's Avatar
Default RE: brakes
ORIGINAL: letsride
and loose nut behind the wheel ha ha ha
you mean behind the bars.
Old 11-01-2007, 06:00 AM
maninder's Avatar
Default RE: brakes
Have got steel lines,have checked mounting bolts,have bled the system and the pads are about 1 year old.
Old 11-01-2007, 09:28 AM
bobjoezx's Avatar
Default RE: brakes
and like we said... ROTORS
Old 11-01-2007, 11:27 AM
Default RE: brakes
minimum thickness isstamped in "mm" on your rotors, just change a new set and take care of the headache.
Old 11-01-2007, 10:38 PM
maninder's Avatar
Default RE: brakes
Rotor thickness 3.7 mm and not warped.
Old 11-01-2007, 10:47 PM
CBRinPDX's Avatar
Default RE: brakes
and while you are at it.. swap the rotors or ride with the shudder, it's up to you. There is nothing else to do. You never said if the shudder is only when wet and 1 year on pads means nothing. How many miles and how hard you use them is the key.
Old 11-02-2007, 07:04 AM
bobjoezx's Avatar
Default RE: brakes
could have a caliper problem....
Old 11-02-2007, 07:08 AM
maninder's Avatar
Default RE: brakes
Problem solved. I noticed front wheel bearings were slightly worn.I had them replaced & the shudder has gone away. Thanks to everyone for your help
Nytmr
12-21-2013 09:16 PM
CBRInfantry
02-07-2011 09:42 PM
hopz
06-04-2009 01:28 AM
radvoem
12-28-2008 08:38 AM
Quick Reply: brakes
