Bike won't start, possibly a fuel pump related issue
I'm frustrated with the fact that this problem is intermittent. Of all the things that can happen as far as starting and fuel pump issues, what can be intermittent like this?
I've changed the relays so I'm going to assume those are ok for now. Bas can be very intermittent also? My bike just started to work by the way, so I'm thinking it has to a relay or sensor. Can the fuel pump itself, just all of a sudden not work?
I'm holding the ecu isn't bad because I will assume that once it's bad, it's gone for good. Same for the ignition diode.
I might just change out the relays again and the bas. Without doing the fuel pump, do I have pretty much covered my chances of getting rid of this issue permanently?
Thanks.
Thanks.
BBLineBacker81
May 2, 2018 02:18 PM
IIRyan
Mar 10, 2013 07:51 PM
