BIGGGGG PROBLEM
Old Dec 8, 2007 | 07:17 AM
bobjoezx's Avatar
Default RE: BIGGGGG PROBLEM
do you have a Ca version 954... did your exhuast have a o2 sensor in it that you did not reconnect??
Old Dec 8, 2007 | 07:31 AM
stunter411's Avatar
ORIGINAL: bobjoezx
do you have a us or CA version 954... did your exhuast have a o2 sensor in it that you did not reconnect??
its a us 954...and the akrapovic has no sensors at all!!! so even if i wanted to plug in any of them it is impossilbe bc there is no where to plug it in.....
Old Dec 8, 2007 | 07:35 AM
stunter411's Avatar
ORIGINAL: randyjoy
The red light is a "Multifunction Indicator" that tells you something else is wrong.Oil Can graphic means low oil/oil pressure. The blinking code light everybody is thinking of isthe fuel injection system is the FI graphic, also called the Malfunction Indicator Lamp or MIL.
If the F1 light is blinking, it's what you need to count. Both long and short blinks and post. If the Oil can graphic is on,check the pressure switch (making sure oil is fine while running with the bike upright).
o god....but the blinking light only blinks every 5 sec.....and it never ever stops! well i just woke up ill go check the pressure switch and check oil when the bike is runing.......
Old Dec 8, 2007 | 07:52 AM
bobjoezx's Avatar
ok first...... CALM DOWN i can help you figure this out.. i just pulled out my 495 page manual i got on my computer and i found all the MIL codes... also i ask the 02 sensor question becuase if you had a ca version that has a 02 sensor and you did not order the right exhust you wont have any plug in for the 02 sensor.. but i do not think that is your problem, let me look over the codes here and iw ill let you know.. also i will send some screen shots stay on the forum for a while
Old Dec 8, 2007 | 07:53 AM
bobjoezx's Avatar
also tell me more about how it blinks.. blinks once every 5 seconds or how.. i need to know exactly what it blinks
Old Dec 8, 2007 | 07:55 AM
bobjoezx's Avatar
did you remember to plug in your map sensor.. its the one on the right side of the airbox... that is most likely it
Old Dec 8, 2007 | 08:16 AM
stunter411's Avatar
ok cool....yea it blinks every 5 sec...for like 1-2 sec long.. and it never stops! the little oil can thing is on the dash as well....
stunter411's Avatar
ORIGINAL: bobjoezx
yea i did that two....
Old Dec 8, 2007 | 08:18 AM
bobjoezx's Avatar
just one time it blinks or what.. once every 5 seconds?? a long blink is 1.3 seconds.. a short is .5 seconds.. you must have your blinks wrong becuase a short blink every 5 seconds would be the map sensor.. so check that, if it's a long blink that would be 10.. there is no fault code 10.. so check the blinks and see if there is a long blink followed by short blinks or something like that and let me know, do you have a email i will send you some screen shots of the manual for the MIL code list, i tired to upload pictures but it's not saving in a format that the forum supports
Old Dec 8, 2007 | 08:21 AM
stunter411's Avatar
ORIGINAL: bobjoezx
it keeps blinking for ever...and it blinks 1.3 sec long! every 5 sec...its the same speed blinks all the time
