anyone know the consequences or risks of riding my 954 with a blown shock?
Old Jan 29, 2009 | 03:31 PM
Zoli's Avatar
Default anyone know the consequences or risks of riding my 954 with a blown shock?
i have been putting my crashed 954 together and its close to completion now the front shock is leaking and i have been so exctied to start riding again. are there consequences? i rode my 900rr with a blown shock for a while but was nervous. any help? im a rookie haha
Old Jan 29, 2009 | 04:59 PM
Hcstreetriding's Avatar
you mean the seal is just leaking oil? If the seal is just leaking a little you can ride on it, you will just want to replace the fork seals before too long but its not going to fall apart on you. mine are leaking a little too so i will be getting that done early in the spring.
Old Jan 29, 2009 | 10:10 PM
not_agn's Avatar
Make sure to watch how much oil is leaking and where it is going. As it gets worse it makes it to your brake pads.
Old Jan 30, 2009 | 04:33 AM
ag1s's Avatar
in case there is total loss of damping, worse case scenario is death.
Old Jan 30, 2009 | 05:52 PM
Zoli's Avatar
its just leaking, how easy is it to change the seals? they are leaking from an accident i had. thanks for all your help
Old Jan 30, 2009 | 05:54 PM
Zoli's Avatar
loss of damping? whats that im a rook haha sorry
Old Jan 30, 2009 | 06:27 PM
Tacoma747's Avatar
Just ride on the back tire al the time and you will be fine.
I suggest you search around (anywhere) and see what a shock actually does. I guess the correct term might be dampening though. Best I can describe quickly is it keep it from bouncing violently over bumps.
Old Jan 30, 2009 | 09:24 PM
not_agn's Avatar
Well if the shock started leaking after you got into your accident, you might have bent the fork? Causing it to leak.
Old Jan 30, 2009 | 09:41 PM
how long has it been leaking? if you have been rebuilding your bike for six months and its been leaking the whole time and before your crash then that is a different story than if it just started leaking and losing its seal.
Roger cbr
Jan 20, 2014 01:58 PM
Winterwarz
Mar 12, 2010 08:14 AM
hawkwind
The Hurricane Saloon
May 12, 2009 06:46 AM
93cbr1000f
Mar 18, 2009 10:25 AM
AREN
Oct 1, 2008 12:26 PM
