Ant46 honda cbr954rr
Old Jun 9, 2018 | 08:44 AM
Ant46's Avatar
Default Ant46 honda cbr954rr
I need help i live in .Richmond va. My bikes 4th gear keeps jumping out when i try to accelerate can anyone help me
Old Jun 14, 2018 | 10:49 AM
tentacleslap's Avatar
Does it only happen in fourth? If so, that could be a worn component in the transmission. Potentially costly. With something that big, I'd recommend taking it to a mechanic to confirm
If it happens in all gears, check clutch cable adjustment
Old Jun 14, 2018 | 12:04 PM
Ant46's Avatar
No it just happens in 4th a guy said the shift fork is broken or bent im need take out engine and turn it over take off pil pan and second cover amd pull apart trans to replace it
Old Jun 14, 2018 | 12:27 PM
Makes sense to me. Could also be a worn dog
Check the oil for metal shavings when you drain it. Good luck
Old Jun 15, 2018 | 10:01 AM
SteveandMat's Avatar
You don't have to take the engine out. It's actually quite simple to pull the shifter drum and forks. You can see pics in my project build. Pull exhaust right case, clutch and oil pan. There is a very well done how to at the top of the 954 forum. It's a 4 beer job!
I would imagine life is pretty sweet for the 4th gear. Hope it's not a broken gear. That would require pulling and splitting the engine on a bench.
bkubes
Feb 13, 2012 09:35 PM
destindiver1980
Oct 7, 2009 05:57 PM
txridder
Sep 17, 2008 02:31 PM
cleansho93
Oct 14, 2007 11:14 AM
toolfan524
Sep 5, 2006 02:03 PM
