Shifting Troubles
Shifting Troubles
This happened a few days ago.
While I was riding I had shifted up to sixth, lifted the pedal again to verify I was in sixth (someone told me this is bad to do?) and noticed something felt different. It seemed as if there was way too much play.
I went up and down through the gears a couple times to see that they all functioned. I had only had the extra play in sixth.
Then over the following 15 minutes it completely took a dump.
The next time I pulled away from a stop light I couldn't get it past second.
I was already planning on rebuilding the clutch and have all new parts for that. Since this happened I picked up a used tranny on ebay, hopefully with everything I'd need.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Any idea what went out? Any advice? I've never done this before.
Thanks for the replies.
The clutch cable is relatively new.
I took off the clutch cover and was going to replace the plates/springs, but I wasn't able to get the nut off to remove the basket. It had already been re-used and seemed crazy over-torqued.
I'm hoping I'll be able to start working on it in the next week or two.
