About to complete my Project
Old Feb 4, 2010 | 01:20 PM
driyac's Avatar
Default About to complete my Project
Hey guys, I am looking for some more mods and also have some questions that I need answered If you could help.
Well I have almost completed my complete rebuild of my 2003 honda cbr 954 Bought it for 2k salvage.
Have since bought new fiberglass fairings, getting painted flat black on monday. Also rear swing arm powder coated black. Bought a New gas tank
- Cut stock exhaust to 1/3 of size or about 11 inches long.. looks sick.
-repainted the Frame flat black with clear coat
-Painted the Under tray gloss black and the rear tire gloss black.
-I am having trouble though with the front rim, I can not get the rotors off the front bike. I mean the thread lock they used must but just completely glued in. Should I take the wheel to a Honda dealer, Since I need a new tire put on and have them take it off?
What other mods have you guys done?
I hope to have some pictures by next friday, im doing the paint job myself as I work with ppg directly.
Old Feb 4, 2010 | 06:20 PM
letsride's Avatar
To remove your rotors use brute force or use a heat gun to warm up the locktite and then try again.
Old Feb 4, 2010 | 07:15 PM
driyac's Avatar
I actually realized i was using standard allen wrenches and not metric... Went and got metric and it worked perfect... I have the front rim painted now... so check that off my list...
Have you done any mods yet?
Old Feb 5, 2010 | 01:57 PM
letsride's Avatar
Quite a few,air box mod,chain and sprocket kit,hid lights,brow lights,power commander,smog block off plates,quick throttle,GP shift,and others I can't think of right now.
Old Feb 5, 2010 | 04:22 PM
driyac's Avatar
Well I have the ****iest luck ever... I have a pinhole size hole in my fuel line thats leaking gas. I took the lines off and cut off the bad hose and tried reinstalling. Its not leaking but i ran out of gas... I hope because my engine started misfiring and all kind of stuff... When i slosh the tank though theres not liquid sound, so im hoping its only a no gas problem...
Old Feb 5, 2010 | 06:17 PM
esteban954rr's Avatar
lol yeah it is most likely out of gas...
i've had this happen before.. would love to see pics of your progress!!! Good luck!!!
Old Feb 6, 2010 | 09:24 PM
driyac's Avatar
Give me until wednesday or thursday... Fairings are getting preped and painted on monday... not sure though if im just going to use ppg primer and then flat clear it or go primer with flat black color then flat clear... I may try to do it in water color with metallic in it... that would be nuts..
Old Feb 7, 2010 | 04:50 AM
sounds good!!! cant wait!!!
Old Feb 7, 2010 | 11:30 AM
bobjoezx's Avatar
sounds like a pretty good looking bike coming together..
Old Feb 7, 2010 | 09:03 PM
driyac's Avatar
Well heres the parts list
- flat black paint
- flat black colored double bubble screen
- flat black rear pegs
- aftermarket mini turn signals- color flat black
- integrated turn signals into the headlight
- cut down two brothers exhaust into 1/3 of original size
- removed stock rear seat for targa cover
- rr and cbr engraved brake fluid caps
- hrc bands for brake fluid reservoirs
- repainted stock wheels to a gloss black and as well the undertail
- tidied up the back, with removing stock license plate frame and installed after market frame holder while keeping the original license plate light
- installed stainless steel galfer brake lines
- replication honda stock stickers
- lowered 3 inches
- removed back fender gaurd and chain gaurd
to do list-
- powder coat rear swingarm
- hid low and high beams
- pazzo levers
- ohilins damper
