954RR HELP! good damper?
Old Jan 26, 2012 | 08:22 PM
J0HNDiLLiNGER's Avatar
Default 954RR HELP! good damper?
i need to install a steering damper, i really like the scotts & gpr but im pretty sure it wont fit with the LSL handle bar kit! what should i do or get?
Old Jan 26, 2012 | 09:09 PM
rehed's Avatar
Get a steering stabilizer that connects between the fork and the frame. A google search should get you pointed in the right direction.
Old Jan 27, 2012 | 03:23 PM
Ironhead's Avatar
Im running a Matris M4R. Love it! Adjusts well for Street and Track conditions. Paid way too much for it. If I had to do it again. It would be a GPR V4. Nothing but good reviews from those who use it.
Old Jan 27, 2012 | 03:38 PM
Conrice's Avatar
the ones you like should mount to your lsl - call scotts or gpr first, but that should mount up... you may have to take the actual bars off, but it should fit the top triple.
Old Jan 27, 2012 | 03:56 PM
Conrice's Avatar
i mean, if you're set on a rotary, that's no problem... this is for a beemer - but it's the same kind of situation you have.
i'm sure if you called gpr, or scotts, they could easily hook you up.
all you need is 2 mounts, and a unit that'll fit. they all do the same thing as far as that company goes...
Old Jan 31, 2012 | 05:22 PM
Ironhead's Avatar
That GPR makes me Hawt.....
Old Feb 17, 2012 | 12:35 PM
thanks alot guys, im a fn burnout cause i remember wanting to post this but i didnt actually think i did n i posted the same question again lol. canrice it looks like ur gap between handle bars and triple tree is alot larger than mine. does any 1 have this on a cbr? the triple tree doesnt sit flat on the 954, it raises right wer the gpr would go! ok lets say it does fit, should i go GPR or SCOTTS? i seen a nice damper made by sprint any 1 have any intel on sprint stablizers?
Old Feb 17, 2012 | 01:12 PM
heres wut im working with, hair more than an inch maybe almost 2"
Old Feb 17, 2012 | 03:42 PM
Starfire954's Avatar
My 954 came with a new Scott's on it. I like it, but it's the only I've tried(besides the invisible oem HESD on the newer CBR1000RR).
Old Feb 17, 2012 | 04:21 PM
ajzcamaro's Avatar
I have a Hyperpro RSC damper that works great. Not sure how your setup looks from above but would this type work?
