954RR HELP! good damper?
i need to install a steering damper, i really like the scotts & gpr but im pretty sure it wont fit with the LSL handle bar kit! what should i do or get?
i mean, if you're set on a rotary, that's no problem... this is for a beemer - but it's the same kind of situation you have.
i'm sure if you called gpr, or scotts, they could easily hook you up.
all you need is 2 mounts, and a unit that'll fit. they all do the same thing as far as that company goes...
