Can you see where the PC gets its power from
Yea it's grounded to the negative batt....and wiring harnest
All the speedo connected and bolted to the bike?
I had my speedo off the other day and wanted to start my bike but had no prime, so connected speedo but still no prime had to rebolt the fairing bracket back onto the frame for it to work |
I've seen some electronics installed in sketchy ways before. I'm guessing this is related to that power commander.
I have same problem
but no solution till yet FI Light stay on MIL - Continuous On HISS - Continuous On Relay - click noise come Fuel Pump - No priming Fuel Pump - If direct connected it works I am not able to understand what to do? |
Hi what fault codes if any is it showing
No prime can only be a couple of things either the fuel pump is toast or the security diaode is gone , either can be checked in 10 minutes with out pulling much apart., you can test the pump with a multi meter on the plug side(2 pin plug) to see if it's good?, fuel pumps are about $10 to $20, & a diaode is about 10 for $1, I can't remember the type but it's located in the fuse box under your 954rr's seat, & if you have a multi meter, switch it to diaode & check if it's good , "Dude" i've seen this PHD in electrics pull the whole wiring out his cbr1000rr when it was only a failed diaode. Always look to the easy fix 1st as usually it always is . C.W
