954 won't start ,no prime,I've checked everything
I am working on my boyfriends 954rr ,it's a 2002 the bike won't start the fuel pump won't Prime and I've checked everything from the fuses the relays the ignition switch Bank angle sensor I tested the fuel pump and it it works when I run a directly to the battery so I hooked it up on a toggle switch check the spark plugs ECU and nothing I'm confused and frustrated help please help
Did you check for 9v on the pink wire on the ignition switch?
Still nothing
Originally Posted by 74demon
(Post 1307826)
The engine is cranking, correct?
So all your lights are on but when but when you turn the key nothing happens??... right.. have you checked the starter? ..... is it clicking like it want to turn over?
(Post 1307839)
Originally Posted by Gambeno82
(Post 1307842)
Originally Posted by Poptart99
(Post 1307843)
yes but it won't turn over
Is your 20amp PGM-fi fuse intact
Yes
