954 won't start ,no prime,I've checked everything
Old 09-25-2017, 07:15 PM
Poptart99's Avatar
Default 954 won't start ,no prime,I've checked everything
I am working on my boyfriends 954rr ,it's a 2002 the bike won't start the fuel pump won't Prime and I've checked everything from the fuses the relays the ignition switch Bank angle sensor I tested the fuel pump and it it works when I run a directly to the battery so I hooked it up on a toggle switch check the spark plugs ECU and nothing I'm confused and frustrated help please help
Old 09-25-2017, 09:05 PM
74demon's Avatar
Did you check for 9v on the pink wire on the ignition switch?
Old 09-26-2017, 12:44 AM
Poptart99's Avatar
Default Still nothing
yes and the diode in the switch is good ,I just got done checking and cleaning the injectors and still nothing
Old 09-26-2017, 08:53 AM
74demon's Avatar
The engine is cranking, correct?
Old 09-26-2017, 09:39 AM
Gambeno82's Avatar
So all your lights are on but when but when you turn the key nothing happens??... right.. have you checked the starter? ..... is it clicking like it want to turn over?
Old 09-26-2017, 09:40 AM
Poptart99's Avatar
yes but it won't turn over
Old 09-26-2017, 09:45 AM
Poptart99's Avatar
yes all the lights are on ,the only thing is the fuel pump won't prime so I ran it sraight to the battery on a toggle ,and also the power comander won't work on the bike anymore ,but it gets power when I hook it to my laptop so I know that the power comander is still good.
Old 09-26-2017, 11:01 AM
74demon's Avatar
Cranking and turning over are the same thing. Which is it?
Old 09-26-2017, 11:07 AM
CaBaRet's Avatar
Is your 20amp PGM-fi fuse intact
Old 09-26-2017, 01:33 PM
Poptart99's Avatar
Yes
Quick Reply: 954 won't start ,no prime,I've checked everything
