954 Hotbodies Undertail Kit
Old Aug 27, 2008 | 12:23 PM
buffddy16's Avatar
Default 954 Hotbodies Undertail Kit
I got the Hotbodies Undertail Kit for my 954 but the directions blow cant see any of the pictures to go buy. Anyone have any tips on the install?
Old Aug 27, 2008 | 01:43 PM
Ironhead's Avatar
Default RE: 954 Hotbodies Undertail Kit
Be very careful when you make the cuts on the stock piece. Its easier to chip away at it. If you take too much material....your screwed. I used a dremel. Remove the whole stock tail piece. Its easier to work with when off the bike. Then start cutting away. When you think you are close. re install the stack piece and then fit the Hot bodies to see where you are at. Its a bitch. But take your time and it will be well worth it. Dont rush this job.
Old Aug 27, 2008 | 01:54 PM
buffddy16's Avatar
what part of the stock tile do you need to cut off? is that lip that the stock undertail sets in?
Old Aug 27, 2008 | 02:11 PM
Ironhead's Avatar
Hopefully this pic helps. You can clearly see how much I left of the stock fender. Keep cutting back the fender until the Hotbodies sits flush on the fender. On the edges. You make the cuts so the stock bolts that hang the fender are left intact. The whole rear section of the stock fender are chopped out. My Autocomm, PC3 and UFO light kit are blocking the rest.
Old Aug 27, 2008 | 02:17 PM
Ironhead's Avatar
Keep trimming and fitting the tail piece. You should end up with a nice clean fit when done. No gaps. As a side note. Take the piece of foam tape under the rear light on your stock tailpiece and gently remove it. Install it on your undertail under the tail light as well.
Old Aug 27, 2008 | 02:21 PM
buffddy16's Avatar
thanks for the pics that helps a lot
Old Aug 27, 2008 | 02:34 PM
Ironhead's Avatar
Good Luck Buff! Dont start cracking open the beers until your done with this project. Have patience with it. You will love the way it cleans the butt of the 54 up!
Old Aug 27, 2008 | 02:41 PM
buffddy16's Avatar
yea ill just pop a few perkisets to help with all the headaches im gonna get puttn this thing on and maybe a budwiser or two to help me consentrate haa. thanks for the help Ironhead
Old Aug 27, 2008 | 04:12 PM
YAM93's Avatar
NICE job IRONHEAD. I wish mine looked that clean. It looks pretty good on the outside though, and keeps gloves and registration papers from falling out the ****-end.
[sm=smiley33.gif][sm=pcwhack.gif]
Old Aug 27, 2008 | 07:11 PM
Ironhead's Avatar
Thanks! The pics they include from Hotbodies looks like it came from the art department at Goodwill. They were useless. I had to hook up a fellow 954er
