954 gear ratios
Old 11-14-2012, 07:20 PM
drake5.0's Avatar
Default 954 gear ratios
i have a 2002 954rr and at 60 MPH(96 KPM) and im turning 3,800-4,000 RPM's. Is that good? i have 16 tooth front and 43 tooth rear sprockets.
Old 11-14-2012, 09:10 PM
LasVegasHarley's Avatar
That is the stock sprocket setup for the United States. I think they had 16/42 in Europe.
I am running 16/43 (2.6875:1) Right now and at 75 MPH the tach indicates 5000 RPM.
I have a 15 tooth front sprocket in my toolbox. I am waiting to get a speedo DRD to correct the speed reading when I install the 15/43 (2.8666:1) combo.
That 15 tooth front will raise the RPM's a few hundred (6.6% higher) at freeway speeds, but should provide a little more acceleration, for even more fun.
Old 11-14-2012, 11:01 PM
drake5.0's Avatar
i kinda wanna do a 17 tooth front and a 40 tooth rear do u think that is a good idea on my engine and transmission behalf
Old 11-21-2012, 12:14 AM
No. I think you will wear out your clutch with that tall gear and the bike would be SLOW to accelerate.
Old 11-26-2012, 01:30 PM
mm3000k's Avatar
i would agree, i would keep close to stock, try a just going a tooth if your looking for mileage, down in front, up in rear will give better accel, vise versa will give more top end, but i wouldnt go to tall and get the rpms to low
Old 11-28-2012, 10:12 AM
m320's Avatar
What are you wanting the bike to do?
sirenformula350
08-14-2019 09:48 AM
demonchild
09-22-2007 12:15 PM
consig
02-20-2007 08:50 PM
kludgeS13
02-20-2006 02:11 AM
CodeToade
08-09-2005 05:09 PM
Quick Reply: 954 gear ratios
