Gear Ratios
Old Sep 10, 2007 | 05:57 PM
demonchild's Avatar
Default Gear Ratios
Need the stock gear ratios for the 954. Specifically the 03 if there was any difference between the 03 and 02. Someone post the up pls.
Old Sep 10, 2007 | 07:48 PM
bobjoezx's Avatar
Default RE: Gear Ratios
http://www.aperaceparts.com/tech/CBR954RR.html
gear ratios and other specs.. 2002 and 2003 are the same bike.. just different paint
Old Sep 11, 2007 | 11:02 AM
demonchild's Avatar
awesome. thx bobjoe
Old Sep 15, 2007 | 10:55 PM
sesshou's Avatar
hi, anyone try a front 16 and rear 46 before...... any feedback . intend to change my sproket very soon.
Old Sep 15, 2007 | 11:24 PM
StuntinThe954rr's Avatar
ORIGINAL: sesshou
i have a 54 on the rear. it will have better low end, top speed will drop alittle....
Old Sep 16, 2007 | 11:34 AM
bobjoezx's Avatar
ORIGINAL: sesshou
i had similar, it will give more low end power, if you do alot of street riding i wouldn't go any more then that, remember also aluminum sprockets are lighter but will wear alot faster
Old Sep 16, 2007 | 11:35 AM
bobjoezx's Avatar
ORIGINAL: StuntinThe954rr
ORIGINAL: sesshou
pretty extreme for street riding...
Old Sep 17, 2007 | 10:59 AM
sesshou's Avatar
ORIGINAL: bobjoezx
ORIGINAL: sesshou
Bike is use mainly on the street but sometimes on the track. I have a micron serpent on it ..... and was wondering a 46 rear is it too much power at the lower end. i intend to get the afam steel sprocket which i think will last longer.
Old Sep 17, 2007 | 02:57 PM
bobjoezx's Avatar
steel will last longer.. about 2-3k.. but all depends on riding.. more track use.. less life.. 46 rear with a stock 16 is alright i woudlnt go anymore then that, maybe try -1 first..
Old Sep 19, 2007 | 12:12 AM
richhowerton's Avatar
I am running -1 in ft and + 2 rear and I like it. It is a little much for the strip hard launches but in the st I love it. I was + 4 in rear and it was too much for everyday ridding. I am running vortek and have not had much prob with them.
