954 fueling issues - short twitch/cut in fueling on highway?
Old May 4, 2021 | 09:53 AM
Rojola's Avatar
Default 954 fueling issues - short twitch/cut in fueling on highway?
I have an '03 954RR with about 25k miles on her.
On highways when I'm riding at steady speed, every now and then there is this small twitch in fueling - like it would cut it off for just a split second. It would do this only once and then it goes like nothing happened. After some time it would do it again. It is more of an nuisance than a problem, but something is obviously off.
There has not been any other issues and the bike had a big service with valve inspections etc. done last summer or so. There is an aftermarket exhaust that has been placed by the previous owner.
I heard the fuel pressure regulator might need to be replaced. Any other insights to this issue?
Old May 4, 2021 | 03:03 PM
@Rojola Welcome to the forum. I'm curious about the sensation when it occurs. When you're describing it cutting off, is it like the ignition is suddenly turned off, or a sputter and slow down?
Old May 5, 2021 | 01:17 AM
Rojola's Avatar
Originally Posted by IDoDirt
@Rojola Welcome to the forum...
Thank you!
The feeling is like throttle would go 0% for a split second. Not sure if that would be different from the ignition to go off for a split second In any case, it is a very short time - a blink of an eye, but it is clearly there and you can hear and feel it when riding.
There is no sputter (sputter as in definition "make a series of soft explosive or spitting sounds.") nor slowing down per se, as it all happens very fast with quick recovery.
mikail2456
Oct 9, 2017 04:53 PM
Steve Theodore
May 30, 2012 09:54 PM
ricerooster
May 28, 2009 02:41 PM
skip954
Sep 8, 2008 05:54 PM
